This is a relatively trivial one that bugs me once in a while.
If we have a control or indicator (e.g. named "numeric") and make a copy of it, the new control is named "numeric 2". (followed by "numeric 3", "numeric 4" etc. if we make more copies).
Basically, if the label contains a trailing number, the highest existing number will get incremented by one for the new copy.
What's wrong with this? You ask...
Let me explain: In labVIEW most things start counting with zero (e.g. array indices, iteration counters, etc.). For consistency, the original control should be considered "zero", so the first copy should be called "numeric 1" instead.
Interestingly, if we initially rename the control to "numeric 0", the first copy will be called "numeric 1" automatically. Why is "1" skipped if the original label does not end in a number???
