THIS IS A REPOST FROM THE MAX IDEA EXCHANGE BECAUSE WE DON'T ACTUALLY HAVE A DRIVER IDEA EXCHANGE AND I DONT KNOW IF THE MAX IDEA EXCHANGE IS CORRECT
Before I start, I want to make clear that I am fully aware that my suggestion is probably linked to some crazy amount of work.... That being out of the way:
I often have to switch between LV Versions and have on more than one occasion run into the rpoblem that different versions of LV work with MUTUALLY EXCLUSIVE sets of drivers. This means that I cannot (_for example) have LabVIEW 7.1 and 2011 on the same machine if I need to be coding GPIB functionality over VISA because there is no single VISA version which supports both 7.1 and 2011 (image below).
Of course these days we just fire up a VM with the appropriate drivers but for much hardware (Like PCI or Serial or GPIB) this doesn't work out too well.
Why can't we have some version selection ability for hardware drivers. Why can't I have VISA 4.0 and 5.1.1 installed in parallel and then make a selection of which version to use in my project definition? I know that ehse drivers probably share some files on the OS level so it clearly won't work for existing driver packages but for future developmend it would be utterly magnificent to be able to define which version of a hardware driver (Or even LV Toolkit like Vision) should be used ina project.
Shane.
