User | Kudos |
5 | |
3 | |
2 | |
2 | |
2 |
Maybe there is a very good technical reason why this idea is not a good one.
Problem: If I want to load a vi into my application the subvi's of the dynamically loaded vi can not be found.
My Plug-In Application (EXE) is Not Calling My Plug-Ins Correctly
Solution: Add a boolean input (or an options flag) to Open VI Reference which will load the vi and modify the search path so the subvis can be found.
I know there are several workarounds but I would like this to be easier.
