I just ran into a situation today where I had a case structure with approximately 64 frames in it, 48 of which I wanted to remove.
The method of right-click the selector, select "Remove Case" (This step is right beside the "Insert Case" which is frustrating), repeat 48 times while the mouse is wandering all over the screen between the case selector and the menu selection..... cue carpal tunnel problems.
I really wished I could just either use the "delete" and "insert" buttons to mimic the appropriate menu selections
-OR-
Be able to select multiple cases from the "Rearrange cases" window and select "Delete".
Available in LabVIEW 2020 and later. You can now remove frames from a multi-frame structure from the 'Rearrange Cases' dialog. This operation supports multi-select, so multiple frames can be removed in a single operation.
