User | Kudos |
10 | |
7 | |
3 | |
3 | |
3 |
We've had a few recent discussions relating to labels of block diagram objects. I don't think the following came up yet, but I think it's one area where improvements are really needed.
If we create a property node or invoke node, it has a label indentical to the linked object. However, this label can be changed to anything we want, possibly leading to code that is very confusing! For example if we had two terminals labeled A and B, we could label the property node linked to A with "B" and vice versa, completely obfuscating the code!
(The beginner could also incorrectly assume that changing the label is the correct way to change the association to a different terminal)
These nodes should really have the label of the linked terminal hardwired to the corresponding terminal name, because anything else simply would not make a lot of sense.
My graphic is not as nice as Jack's here, but I think the idea is clear. It would certainly need a few tweaks from the art department. 😉
We might need an option to hide the label. Oversized labels should be truncated for display, only showing the full text when hovering.
