Problem: Currently, the native nodes and VIs that can be used for error manipulation are located in the Dialog & User Interface palette. While manipulating errors can mean generating dialogues, and can influence the User Interface/User Experience, error manipulation is a broader and stand-alone topic.
Solution: Nodes and VIs that are relevant to error handling/error manipulation should be given their own subpalette inside the Programming palette. The new subpalette could be named "Error Handling", "Error Manipulation" or "Errors".
