ouadji
Event Timeout Terminal (Event Structure)
Status: New
                  A picture's worth a thousand words
                                                     but,
8 Comments
Mads
Nice to remove the branch, but do you then want the output from the clock to be the actual time since the previous? (The actual time between two timeout event is likely to deviate a lot from the set value (especially because other events will interfere), so if the use case is to calculate a total time of something you should do it differently.)
RavensFan
Knight of NI
No.  His idea is strictly to fix the location of the timeout terminal.  Nowhere does he discuss changing the definition of the wire leaving the timeout terminal.
Actually this seems to be somewhat of a duplicate of thie idea Allow Timeout Terminal on Event Structures to Move
ouadji
Trusted Enthusiast
@RavensFan :
No, his idea is strictly to fix the location of the timeout terminal.
pouce-haut.gif  That's right!
X.
Trusted Enthusiast
Trusted Enthusiast
That's called a bug report. Nothing wrong with posting it in the Idea Exchange to grab attention though.
Darren
Proven Zealot
Status changed to: Completed
 Available in LabVIEW NXG. The timeout terminal on an Event Structure can be moved up and down along the left side of the structure, and its inner terminal is never hidden behind the top side of the structure.
Darren
Proven Zealot
Here is a screenshot:
hunter_jki
@Darren, can this go back to open now that NXG is DOA?
Darren
Proven Zealot
Status changed to: New
