User | Kudos |
8 | |
2 | |
2 | |
2 | |
1 |
I think it is very difficult to make a UI that runs on Windows and interacts with targets. Here are two suggestions to improve this:
1. We currently can't have \c\ format style in a file path control on windows. It would be nice to allow user to specify the OS syntax to use instead of assuming it should always be the local sytax.
2. The icing on the cake would be to have the File Path Control support a property node for an IP Address so when the user clicks on the browse button, it automatically browses the target (this is already an idea mentioned in the link below) and uses the syntax of the target. This becomes especially useful as we start to have targets that may have an alternative way of browsing files besides FTP. It would be a pain to figure out which SW is installed on the target and use the correct method to enumerate files/folders.
These two features could be implemented by having an enum property node for the File Path Control called Syntax which include options like: Local, Various OSes (Windows, Linux, Mac, etc), or IP Address. If IP Address is specified, another property Node called IP Address will be used to determine what target's OS to use (if it's not specified or invalid, we default to Local).
