CM411
Frame to group, comment and highlight parts of a blockdiagramm
Status: Duplicate
It would be useful to have a frame to group, comment and highlight parts of a blockdiagramm.
What is the idea ?
1) If a normally frame is used it don't changes the position when the items (VI's, wires, ...)
change the position.
2) A comment function e.g. "subdiagram label" woud be a help.
3) A grouping function, e.g. "case structure" can help to hold the frame and items together.
4 Comments
Norbert_B
Proven Zealot
Sounds a little to me that you are searching for single frame sequence structures and display their "Subdiagram Label".
Please note that you ought to keep the sequence structure limited to a single frame!
Norbert
Norbert
Expert: Geometry
Darin.K
Trusted Enthusiast
That picture reminds me of my XBox, although I have no interest in grouping the objects.
https://decibel.ni.com/content/docs/DOC-15362
The problem with the single sequence structure (besides ugliness) is that it adds dataflow restrictions that a decoration does not.
A better looking decoration would be nice, I am not so fond of adding another structure.  If you want grouping you should vote for this:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Grouping-blockdiagram-objects/idi-p/1081057
(BTW what is all of that whitespace?)
CM411
Thanks for your helpful comments, the solution " XBox and Hyperlinks"
should be included into LabView so fast a possible.
I will vote for the grouping idea.
MaryH
Status changed to: Duplicate
