HI,
We are working hard to reuse as many code as possible in ours projects.
I believe that would be handy instead set manually in the sub-panel in the front panel, I could set a property indicating this and LabVIEW does the work importing the panel of the sub-VI as it is, into main VI front panel.
Doing this we will be able to reuse the sub-VI front panel layout and spend less time cloning it or creating its controls and indicators in the main front panel.
Let the sub-panel for VIs that are open using references.
Cheers.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
