ClaudioH
New "Read from spreadsheet" options
Status: Declined
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
Reading your sample code in http://decibel.ni.com/content/docs/DOC-12287 I had the idea that we would be able to inform Read from spreadsheet that the file has row headers and / or column headers.
When setting this, a table indicator should be created as defined by the file instead manually:
- remove the first row and set it as table column header
- make column header visible,
- remove the first column and set it as table row header,
- make row header visible.
Cheers.
CHCastro
1 Comment
Darren
Proven Zealot
Status changed to: Declined
