I'd like to have a PDF export function within the Report Generation Toolkit.
So that no additionl software have to be installed on the target system to generate PDF files including graphics an text.
The PDF format is the most used format for sharing documents because nearly everybody has a reader installed.
It looks identical on every computer and is perfectly to print.
Software like OpenOffice, Word or programming languages like PHP supports the generation of PDF files, why not LabVIEW?
Regards
Available in the Report Generation Toolkit for LabVIEW 2015 or later. If you are generating a Word or Excel report, and you wire a report file path with a '.pdf' extension to the Save Report VI, the report will be saved as a PDF file.
