User | Kudos |
5 | |
3 | |
2 | |
2 | |
2 |
currently, the Select Inspection state [View complete inspection setup-> setup-> select inspection] in Vison Builder for Automated Inspection allows the decision only by numeric or string values.
Therefore if the user wants to only use a few lines/bits, not the whole byte, they need to use LabVIEW step.
If there was a way to mask the input byte or to make the input only from a line/lines it would eliminate the need to use LabVIEW step tp achieve this behavior.
[idea thanks to a customer's request]
Thanks for your opinions!
Zenon
