The Resample IMAQ VI should have the ability to scale the output image to match the input image. If the user only connects one of the X or Y terminals the other one should automatically adjust to match the ratio of the input image. Alternatively there could be a boolean autoscale? terminal which can be used to switch the function on.
Attached is a subVI that does this.
