The templates for XControl properties are quite simple, the standerd input and output controls and the boolean Value control. Nine out of ten times however I find myself doing the same action for every property I create, namely inserting a 'bundle by name' node between Display state in and out, selecting the correct element, change the Value control to the correct datatype and align and wire unbundle node to the value control for a write property and doing something similar with an unbundle for the read property.
Wouldn't it be nice to have the template already have the bundle/unbundle node already inserted and aligned?
Or, even better, wouldn't it be very nice if the "Create Property" dialog would optionally let us select an element from the Display State cluster and just create the code for us.. Look ma, no programming!
National Instruments will not be implementing this idea. There is no further feature development planned for XControls.
