It would be a great add-on if the graphs have got in-built measurement features/properties/methods like an oscilloscope;
- Trigger
- Basic arithmetic function like Ch1-Ch2, Ch1/Ch4, etc.
- Event trigger based on plot value change. Example an event will be generated if Ch1 value is greater than a set value, an event will be generated if Ch2 value is greater than Ch4 value
- In built average plots. Example add plots like 10SMA(Ch3), 30EMA(Ch1) etc.
- Threshold based graph visual property change. Example configurable out-of-threshold or in-threshold plot color change.
Advantages;
- Save time in development.
- Integrated code will be efficient as no data unbuild/build/pass overheads.
- Block diagram would be neat and easily readable.
- Lightweight code.
Thank You
Adarsh
LabVIEW from 2006
CLA from 2014
