X.
Include longstanding "known issues" in the help file
Status: New
NI updater kindly informed me that LabVIEW 2014 SP1 was released (even though I uninstalled it shortly after I tried it last year) and out of curiosity, I took a look at the known issues list.
I learned a few interesting things I did not know about, and also that some problems had been reported as long ago as version 7.1.1. This type of stuff looks like bugs that won't be fixed, ever.
For instance, CAR #48016 states that there is a type casting bug in the Formula Node. It was reported in version 8 and the suggested workaround it to use a MathScript Node instead of a Formula Node (where is the "Replace Formula Node by a MathScript Node" contextual menu item?).
Problem: the MathScript RT Module is required. Even in my Professional Development System, this is not included by default. Does this really count as a workaround?
I read: we don't have the resources to fix that bug, or we don't want to break code that expected that bug.
In any case, this bug with most likely never be fixed.
The bottom line is, we can waste a lot of time as users, rediscovering bugs that have been known for a while and will probably never be fixed. As a user, I would really appreciate a courteous warning from NI that there are known traps and have a complete description handily available with the help file related to the affected function.
My suggestion: add a list of known issues (with link to their description) for all objects, properties, functions. VIs, etc, in the corresponding entry in the Help File.
1 Comment
Henrik_Volkers
Trusted Enthusiast
KUDOS!
I would like to have it in the 'header'  of the helpfile whenever there is a CAR (still) open related to this vi while version release !!
Details   Example    Known issues
Greetings from Germany
Henrik
LV since v3.1
