With reference the post in the below link
The idea of decreasing the size of the "close reference" works fine if you wired from a propert or Invoke Node, It won't fit for the references coming out from VIs.
So my idea is to slightly increase the size of "Propery Node" and "Invoke Node" so that it can fit with VIs as well as "Close Reference".
Sample screen is attached Below
If you like this Idea don't forget to give kudos,
Best Regards
SamuelJ
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
