Scroll bar should be disabled if all elements are visible! Kudo here to get a big bang for the buck sooner than the 2nd in TOP KUDOED IDEAS from 2013 with 600+ kudos (https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Indicate-that-array-constant-contains-more-elements-t...). It points out that the scroll bars are not a viable method because it looks the same when all elements are visible. That is EASY to fix; disable the scroll bar if ALL elements are visible! Currently it is disabled only if an empty element is visible. Perhaps the behavior was originally by design like block diagram scroll bars as mentioned in the reason that the following was Declined, '...without this "boundary", it is impossible to create more space...' but constants can easily be stretched by border handles to create more elements (https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Make-window-scroll-bars-reflect-actual-contents-of-wi...).
