The default widths of the LLB Manager window and the Name column in the multicolumn listbox are too narrow (see the attached picture). They should be widened considerably so VI names are completely visible without having to resize the Name column and LLB Manager window.
The multicolumn listbox displaying items should be replaced by a regular single column listbox since only one column in the multicolumn listbox is actually used. This would allow for listbox scaling due to window size changes to work much better. Currently, when you resize the LLB manager window, the multicolumn listbox resizes as expected, but the width of the Name column doesn't change accordingly, which means you often have to manually resize the column when resizing the window.
You should be able to select multiple items in the listbox, such as VIs, and open them by pressing the Enter key (like the behavior in Windows File Explorer). The only way to open multiple items from the multicolumn listbox currently is to select them and then right click on them and select Open in the shortcut menu.
