LV2021 has a new "feature" called "Auto-Routing" (this is not Auto-Wiring, which can be deactivated in the options!). Auto-Routing moves wires around if you touch for example Sub-VIs.
Especially in compact VIs this function is a disaster right now. Sometimes for example wires will go "through" Sub-VIs so that an output leaves the Sub-VI at the wrong side resulting in a VI which is terrible to read:
1. Original Snippet of a VI:
2. Same snippet, I just moved the "Get Variant Attribute Function" by one pixel to the right:
First we thought this is a bug, but the support told us it is a feature. But please: Let us deactivate this "function" in the options. I have colleagues telling me they would stop using LabVIEW if this remains as it is right now.
In LabVIEW 2021 SP1, the automatic layout of wires when moving diagram objects is disabled if "Enable automatic wire routing" is unchecked in Tools>>Options in the Block Diagram category.
