pavanb
Labview embedded everywhere
Status: Declined
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
Would like to target Labview embedded on a host of platforms. Specifically x86, lynuxworks, Vxworks and xilinx platforms - boards, SBCs, COMs, stacks, PC/104... Like PXI, the way to get the users onboard is to show that the industry supports this direction and you are not tied to one vendor. It would be expensive if in an iterative learning process (necessary but collaboration is also necessary with well established & matured platforms/standards) the users one chosen platform vanishes (maybe like fieldpoint?). Packaging options is also very important to achieve something like Adlink's MilSystem 800 that the application demands.
Pavan Bathla
3 Comments
G-Money
NI Employee (retired)
Are you referring to the LabVIEW Embedded Module for ARM when you say you would like to target LabVIEW embedded on other hardware?
vitoi
LabVIEW Embedded for ARM would be suitable for some of the targets. However, we need more Tier 1 boards. There are only currently two Tier 1 boards and they are over 6 years old. Need a contemporary Tier 1 board, such as the Arduino Due (ARM microcontroller).
Darren
Proven Zealot
Status changed to: Declined
