The Save As option is not always available from the right-click menu for items in a project/library. It seems to be dependant on if/how the item has been loaded into memory.
It would be nice if this option was always available to allow easy duplication of VIs. It should open up the default Save As dialog (as below).
Available in LabVIEW NXG 1.0. When you right-click a GVI in the project, you always have the 'Duplicate' and 'Rename' options available.
