Make current values default - Excluding Large Data
Subject:
Improve "Saving Default values" option, adding the possibility to EXCLUDE data of certain kind of control or
exceeding a certain size.
The typical case of use
You use LV for developing data analysis software, or for data reduction. You want to save the values of parameters which give you a certain result, but not the result itself in the case its too huge.
In my case "result" = a number of Intensity Graph controls each one of 2048x2048.
Why that?
To reduce VI size, saving time and improve VI startup after small changes. This encourages the use of LV as "scripting" (or "sketching", as I like to say) language.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
