I am currently struggling with the issue that the shown knob permanently triggers "Value change" event as long as the user has not finished adjusting it yet (left mouse button is still pressed). This may be an intended behavior, but it is not in my case.
For boolean elements, there is the configuration option of "Mechanical Action". For strings, there is the option "Update value while typing". However, there is currently no such option for numerical elements.
Therefore, I would like to suggest the following:
Add an option "Update while adjustment" - true by default, so it acts as it do currently. If this option is set to false, the "Value change" event would only be triggered after the input is completed by the user.
Create a "User Control Ended" Event - NI Community
