In .NET each of the integer data types provides two constant fields, named MinValue and MaxValue. These constants return the minimum and maximum values that can be stored in that data type. For example, for Int32 MinValue would return -2147483648 and MaxValue would return 2147483647.
It would be nice if there would be similar constants in LabVIEW for all eight integer data types. These constants would be similar to the DBL constants that already exist: +Inf, -Inf, Machine Epsilon and NaN, and would be similar in concept to string constants such as Space Constant and End Of Line Constant.
The new constants could be placed in the Numeric palette, or in a new sub palette of the Numeric palette, as shown in the image below. I would be happy with any location.
I am aware that I can easily create constant VIs to implement this functionality, which would be very similar to how Space Constant.vi is implemented, but it would be nice if the constants were built-in.
My current workaround when I need the min or max values of an integer data type is to drop a numeric constant and type something like -9999999999999999 or 9999999999999999, which after Enter is pressed LabVIEW correctly coerces to the min or max value.
