I rediscovered a kind of an annoying behavior with multiplot XY-Graphs which appears to have existed since LabVIEW's emergence. Say I want to use the XY-Graph like a curve tracer, thus adding XY data pairs to an existing multiplot XY-Graph by passing the array of array clusters around in loop shift registers and fill in new data as it's produced. This all works well BUT when adding multiple plots in different colors it shows that consecutive plots are always drawn underneath the already existing ones instead of the other way around. I find that new plots should be drawn over already existing ones also according to the sequence shown in the plot legend.
If your new plot has the same or similar values than the previous one then the second plot will be hidden underneath the first one. You can only see a second one if the values are different. It's counterintuitive I think and I wonder why it has always been like that.
I plead for a XY-Graph option along with a property node to change this so that new plots cover old ones when they intercept. The legend sequence should not be changed because the top to bottom order is correct.
I demo VI of the misbehavior is attached
I hope I get enough support for this to be done.
Urs
Urs Lauterburg
Physics demonstrator
Physikalisches Institut
University of Bern
Switzerland
