For the moment the INI file is managed as global feature (Link in the executable : Link to Labview.ini by default )
I think the INI keys are part of the project.
So it would be more "User Friendly" to be able to edit them as "Project properties". (Like conditional disable symbols)
Associated directly the INI keys to the project will avoid to lost important part of your application.
For example the key "useLocaleDecimalPt" is usefull when you want to force the decimal point to ".".
This is usefull when you use "Instrument drivers" which are decimal point dependant ... but don't alert when the active decimal point is ','.
I think that ini keys are part of the source code. So theire place is in the project, as project properties ... (Not globaly managed in the Labview directory)
I think that adding INI keys to the project will limit the problem of "source lost" when you many personns works on the same project ...
Or when you had to modify an old project on a new installed PC.
For the moment, I create my own local INI File in my project ... but it is not user friendly, it's manual !
Any idea that has received less than 10 kudos within 10 years after posting will be automatically declined.
