User | Kudos |
10 | |
6 | |
6 | |
5 | |
4 |
In the same way that mouse clicks, key presses etc can be filtered or modified before being accepted, having a Value Change? event option would allow tighter control over input data than possible using the Data Entry tab, and without needing to wire to a Value property node or local variable as AQ suggests here.
While this idea in itself probably doesn't make much difference, it would be very useful if such an event could be "bound" to a .ctl (a sort-of mini-XControl) in an enhanced version of what the Data Entry tab currently does.
