I would like to see the functionality of the TCP and UDP primitives expanded to include more state information, better control of the connections and the capability to receive events for the connection.
Items that I can see which would be helpful would include the following:
- Ability to enable/disable the Nagling algorithm.
- Ability to abort a TCP connection with a TCP-RST. (The wire is there on the TCP-Close primitive but it doesn't do anything)
- Ability to receive an event when data is present.
- Ability to receive an event when the data has actually be put on the wire. (Currently the write VIs return as soon as the data is buffered. There is no ability to have the application wait until the data is actually delivered.)
- More access to the IOCTLs that are available on a socket connection that a programmer has access to via Linux or Windows socket libraries.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
