Here is my idea:
When searching for something in quick drop, you should be able to press shift and double click on an item and have it either insert it onto current wire(s) or replace the current node.
Background: I usually either use a shortcut for the exact thing I'm looking for or else use the arrow keys to navigate down to it and then press ctl+p or ctl+i. But in some cases I am trying to insert or replace a node I don't use often and it might be near the bottom of the list. It's more convenient to use the mouse to click on it rather than a bunch of down arrow presses. But then I have to move my hand back to the keyboard to do ctl+p or ctl+i, which is not convenient. It would be nice if I could just press shift or some other modifier and double click and it would automatically insert or replace (I think it could figure out which to do by context).
Edit: I realized that the shift key already means something because it modifies how the insert works (whether to insert on each wire or onto both wires). Therefore I would propose a different modifier key, like alt+double click inserts or replaces, and shift+alt+double click inserts or replaces with shift modifier.
