The same Menu Shortcut (Control-E by default) is currently used for both switching between Front Panel and Block Diagrams in VIs, and for switching between Items and Files views in the Project Explorer. Because these are linked, it is not possible to change/remove only one shortcut. Like others, if you have a large project, switching views can take a long time, and it's easy to mistakenly hit it when the Project Explorer has focus, rather than the VI you think you're looking at.
The idea is to separate the Shortcuts used for these two operations. This matches several of the comments on that previous idea (but not the idea itself).
