Manzolli
Repetition Structures Breakpoint Better Indication
Status: New
When we put a breakpoint inside a repetition structure LV runs the code inside loop before it stops. If we want to break before the 1st iteration we need to add a breakpoint outside the structure. The current way doesn't communicate the actions properly. I propose a slightly different way to communicate it:
The left border acts as the outside border and the other three as the inside current one.
André Manzolli
Mechanical Engineer
Certified LabVIEW Developer - CLD
LabVIEW Champion
Curitiba - PR - Brazil
13 Comments
Intaris
Proven Zealot
Personally, I would remove the horizontal red lines for the proposed "Stop at the end of all iterations" option.
Either Left side, Right side or all.  It's pretty easy to distinguish them from a distance whereas the top-right and middle-right at the moment are a bit too similar for me.
Manzolli
Nice touch. It would make it even lighter.
André Manzolli
Mechanical Engineer
LabVIEW Champion
AristosQueue (NI)
NI Employee (retired)
Intaris: I was working up images just like that when I saw your post.
Manzolli
Thanks! Smiley Happy
André Manzolli
Mechanical Engineer
LabVIEW Champion
Dragis
The mockup for stopping before each iteration seems a little counter intuitive to me. It would seem to imply it would also stop at the end of the last iteration. Also, there is no mockup for what it would look like to stop only after the last iteration is complete. Anyone want to take a shot at those?
Manzolli
How about that?
André Manzolli
Mechanical Engineer
LabVIEW Champion
AristosQueue (NI)
Mix and match the four settings how you will...
Manzolli
Aristos' proposal enhances also LabVIEWs behaviour.
André Manzolli
Mechanical Engineer
LabVIEW Champion
Dragis
Those mockups look great.
jcarmody
Trusted Enthusiast
Be careful!
Jim
