User | Kudos |
5 | |
3 | |
2 | |
2 | |
2 |
Curently, when we use the Open VI Reference node, there is a numeric "options" input for specifying how to open the reference. For example, 0x01 for "record modifications", 0x02 for "open templates for editing", and so on.
To my best knowledge, the theory here is that is makes it "easy" to combine options, e.g. 0x03 to "record modifications" and "open templates for editing". The problem I have with this method is that 90% of the time I cannot remember the number to go with the option(s) that I want - I end up opening Context Help->Detailed Help, etc.
An alternative way would be to copy the VISA Flush Buffer node: use a ring control for each of this input. that way you could just select the "record modifications" option, or, if you need multiple options, combine them with a OR or compound logic node (or even, take an array of these options as the input, allowing 0 or more options to be select). This to be would be much easier as we wouldnt have to keep on going to the context help.
Let's make it happen! 🙂
Shaun
