JÞB
Resettable Queue Max Elements
Status: Declined
Moved to CAR database. CAR#241807
I Hit on a post today that required a Queue function "work-a-round"
The Poster simply wanted to reset the property "Queue.MaxLen" and that property is quite buried.  (and look at the bug in probes on queues where "number of elements in queue" must = "0").
One solution was: ReSizeQue.png
A better (IMHO) solution would be to drop the "set" method of "Get Queue information" function on the BD and solve the problem with a single call of a vi.lib object.
"Should be" isn't "Is" -Jay
9 Comments
JÞB
Knight of NI
Not sure Why the .png ARGHHHH. the .png is fixed
JÞB
Knight of NI
OP Here- by For(imstuck)
AristosQueue (NI)
NI Employee (retired)
Look where? Nothing in your post or the thread tells me what bug you're complaining about. I probed the queues in your picture when they had zero elements. Didn't see anything wrong with them.
RavensFan
Knight of NI
Aristos Queue.
I believe he is referring to CAR241807 Probe provides incorrect information about Queue Status
JÞB
Knight of NI
AQ-
Ravens correct. Thanks for the link.  Probing when the queue has data the probe still shows 0 elements
AristosQueue (NI)
Regarding the CAR: I looked into it, then I updated comments in that thread and updated the CAR with the actual issue. Workaround: Write a custom probe and do not use the To Probe String primitive.
G-Money
Status changed to: Completed
G-Money
I am changing the status from Completed to Declined because Completed should only be ideas that R&D see on Idea Exchange, actively developed on it based on the idea here, and it was added to the product.
G-Money
Status changed to: Declined
