It would be nice if it was possible to restrict the autoscaling (in graphs and charts) to one direction only, and to limit its operation to a certain range. A typical use for this would be to set the scale minimum to zero - and then let the autoscaling adjust the scale maximum.
You can of course achieve this by writing your own autoscaling function, however the need for such coding could easily be eliminated by adding a few options to the already existing feature.
In addition to the directional limit and range it could have variables like a minimum step size / maximum allowable overshoot, maximum number of points off-scale etc.
