AudioVideoDisco
Retain all errors option of Merge Errors.vi does not output a valid JSON string
Status: New
Current Behavior:
When using the "retain all errors" option of the Merge Errors function the combined error message JSON output is not a valid JSON string.
This is the source output of Merge Errors when retain all errors is active - it is not a valid JSON string.
<JSONErrorMultiple_1.0>[{
    "status": true,
    "code": 111,
    "source": "This is a test message including\nnewlines"
    "status": true,
    "code": 222,
Desired Behavior:
Make the combined errors source string a valid JSON string so that it can be parsed by other tools.
Valid JSON string:
[{"status":true,"code":111,"source":"This is a test message including\nnewlines"},{"status":true,"code":222,"source":"This is a test message including\nnewlines"}]
 The above JSON string can be formatted nicely by most tools - e.g. JSON pretty print - https://jsonformatter.org/json-pretty-print
The below string including the JSONErrorMultiple_1.0 key (but formatted correctly) also works:
{"<JSONErrorMultiple_1.0>":[{"status": true,"code": 111,"source": "This is a test message including\nnewlines"},{"status": true,"code": 222,"source": "This is a test message including\nnewlines"}]}
8 Comments
AudioVideoDisco
The following VI snippet VI illustrates the issue.
In short, it would be great if the JSON-like output from Merge Errors.vi was valid JSON format.
fefepeto_kb
I agree that this issue is really strange and shall be fixed.
FYI: the snippets don't work in the idea exchange, as in the forum. Could you please upload you code as a file attachment instead?
joerg.hampel
The snippet works for me if I download it from the detail view.
DQMH® (Developer Experience that makes you smile )
wiebe@CARYA
Knight of NI
Also note the stupid distinction between
and
JSONErrorSingle_1.0
The first is for 1..n errors, the second, completely redundant, is for 1 error.
Look into the multiple error VIs to see exactly how much CPU and code is wasted on this 'feature'.
AudioVideoDisco
@fefepeto_kb I tried to post the actual VI but it won't let me post it on this board for some reason.
wiebe@CARYA
Knight of NI
Attachments aren't allowed on the idea exchange comments...
fefepeto_kb
Hey! Thanks for trying. I also checked the snippet and it worked with the method joerg.hampel suggested.
It seems we have two issues with the forum itself in this post :D. One is that the snippets don't work with resized images, which I think it should, because it is much easier. The other is that VIs cannot be posted in comments. I think it would be useful to share workaround codes here as well.
wiebe@CARYA
Knight of NI
That is a well known issue. It has been like this for years. I assume there are good reasons (bandwidth) to shrink the images and remove meta data like snippets. It might be bad for us, but (marginal)  better for the environment.
