User | Kudos |
10 | |
6 | |
6 | |
5 | |
4 |
I'm telling my strudents how they should use the error cluster and how important it is. In subvis no error dialogs should be shown and so on (see topics of LabVIEW Core 1 / Core 2).
But many VIs written by NI have been programmed very sloppy.
Example: VI "Write into spreadsheet file". The error cluster is not wired to the inputs/outputs and if an error occures, an error dialog would pop up. Here is the block diagram of your V "Write into spreadsheet file"I:
Please check all of your VIs and do a revision that we can make well-coded applications where the error handling will work correctly.
Regards
