User | Kudos |
10 | |
6 | |
6 | |
5 | |
4 |
Currently if you right click on a subVI from the block diagram and choose properties, it brings up the Object Properties dialog. The only options you can change there are label options, which can easily be changed in the "Visible Items" submenu. I can't think of one time when this has ever been what I wanted out of this action. Instead, I think this action should open up the VI Properties Window for the VI.
National Instruments will not be implementing this idea. There are some ambiguities associated with changing VI Properties in relation to a specific subVI node on a diagram, so the most straightforward way to configure VI properties is from an open VI window. The current workaround is to double-click the subVI and press Ctrl-I. More broadly, we are looking at ways to reorganize the right-click menu of subVIs, in conjunction with augmenting the 'Properties' dialog of a subVI, to improve the experience of configuring subVI nodes.
