Currently LabVIEW has the ability to scale almost any object with the pane (e.g. when the front panel is maximized the object is scaled accordingly with the FP).
However once we add a second object that option goes away:
Now you may be thinking that there is a limitation that LabVIEW can only scale one object however there is an option in VI properties to "Scale all objects on the Front Panel." If LabVIEW can scale one object and it can scale one object and it can scale all objects why can't it scale any number in between. There are numerous situations I can think of where developers would want to have control over which objects scale and which do not.
As a workaround to this you can either group the objects you would like to scale or you can choose "Scale all Objects" and lock the ones you do not want to scale but these are both just that, workarounds.
