JÞB
Select represetation for Feedback Node and Shift register.
Status: Declined
Moved to CAR database. CAR#125834
I noticed an odd (undesired) behavior where my SR/FB node acted oddly.
First I created a simple !32FB node
Next I added a +1 primitive to make it a counter....
-  and Smiley Mad my data type changed!  This behavior was undesired and looking through the node RCM and Properties I could not select representationSmiley Surprised
In fact I had to add a conversion. Simillarlly the same thing occured with a USR
I propose adding the ability to select representation to the RCM and Properties pages of SRs and FBNs
SR RCM                                        FBN Property browser
"Should be" isn't "Is" -Jay
5 Comments
RavensFan
Knight of NI
JÞB
Knight of NI
Well then, exposing the "Adapt to entered data" and "Representation" properties via RCM and Property browser may be a good fix for CAR 125834Smiley Wink
I bet I get a quick "Declined-moved to CAR database" and maybe free a NI resource to work on it
G-Money
NI Employee (retired)
Status changed to: Declined
G-Money
You are correct on the Declined-moved to CAR database response Smiley Wink That free resource was helpful because I just tested this out in the LabVIEW 2011 Beta and this behavior has been fixed. No more datatype changes just for adding the Increment.
SteenSchmidt
Trusted Enthusiast
Until LV 2011 a fix is to rewire any of the connections on the feedback node. That'll change the type back to I32.
I don't think the problem lies in the feedback node, but instead in the instance picker when you drop a polymorphic function. The correct instance should be chosen before the poly is dropped into the block diagram forcing the compiler to do type propagation.
Cheers,
Steen
CLA, CTA, CLED & LabVIEW Champion
