Stacked shift registers always has the most recent value at the top, no matter in which direction you start your mouse drag on the shift register node:
Sometimes it could be more optimal to reverse the stacked shift register direction, just for the sake of neat wiring. In that case it would also be necessary with a visual aid (in addition to the tooltip which isn't visible unless you hover your mouse over the object) telling you which is the most recent value; the one at the top or the one at the bottom:
This "dimming" of the older values in the stacked shift register also makes it easier to tell a stacked shift register apart from ordinary shift register that just happen to be very close together.
Cheers,
Steen
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
