User | Kudos |
5 | |
3 | |
2 | |
2 | |
2 |
When I hit CTRL+M to "Change to Run Mode" on a UI front panel, several run-time window properties are applied (scrollbars are hidden, toolbar goes away, closing/minimizing options are applied to window...) except the application menu is still visible. I propose the Run-Time Menu be shown rather than the app menu. The developer should be able to navigate the stubbed menu, just like when using the Preview on the RTM Editor.
(On the menu subject, it would also be handy to see an updated RTM Editor and some Menu Upgrades.)
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
