User | Kudos |
5 | |
3 | |
2 | |
2 | |
2 |
Labview Signal Express:
The only sensitivity units you can select for Acquire Signals >> DAQmx Acquire>> Analog Input>>Force>> Force (IEPE) are mVolts/N and mVolts/lb. When you type in a value less than one in sensitivity (example: ".5"), it puts the unit in "milli" (500m) which is confusing because the actual units should be 500 uVolts/N and are displayed as 500m mVolts/N. It would make more sense if the units were in Volts/N so then the sensitivity for (.5m Volts/N) would be 500u Volts/N.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
