Hi all!
I think that it would be cool to be able to set the "origin" of a slide control. You can do that programmatically by adding a second slide and check for the control/indicator in the block diagram. Right now, if you place one of this controls on the front panel, the origin will be at the bottom of it.
If you open the VI, you will see what I mean. It would be cool to have a Property node where you could set the origin of the slide, just as it has been done in the code with the constant.
Thanks!
