When you use Sort 1D array function, it sorts items but does not output sorted index numbers. This is a problem especially if a particular 1D subarray is used to sort an 2D array and if subarray has identical items in it. It makes it hard to rebuild the 2D array based on the sorted 1D subarray. If sorted index numbers are provided, 2D array can easily be rebuilt.
Declined for reasons listed in AristosQueue's reply
