I was told this is the appropriate location to add suggestions for the Labview development team. Upgrading from an older Labview I noticed that the Stack Sequence is hidden. I appreciate that Stack Sequence is still accessible for now. I understand that the Stack Sequence can create issues. Still at times it can be a valuable tool for some of your users. Even after modularizing code into Vis, Events, and Cases there can be a lot of code that needs to be written. Limiting the amount of code written for a case to the screen size may be too restrictive at times. I mean this a bit figuratively because code can be written outside of the visible area of the monitor. Clearly it is not a popular tool, but it would be helpful to some of your users. I wanted to make the unpopular request that the Stack Sequence not be completely removed from future versions of Labview.
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
