Qizhen
Support Unit in all controls and functions
Status: New
LabVIEW allow you to set unit to the numeric controls.  But if you try to pass its value to some LabVIEW VIs or functions (e.g. "Simulate Signal"), the wire was broken.  LabVIEW VIs doesn't handle the value with a unit.  It makes the unit setting useless!
I got this idea from a Customer, here is his original comments:
"我编写了一个简单的程序,在前面板的旋钮输入控件附上单位vlot,然后在程序框图中放置了一个仿真信号控件,接下来将前面板中的旋钮控件的输出端连接至程序框图中的仿真信号控件的幅值输入端,但在即使帮助窗口中出现了一个错误,为:数据源的数值单位为volt,数据接收的单位为no Nuit,当然程序就不能运行了。于是我采用通用单位符$1的办法也没成功,最后从网友那儿得知在LabVIEW中只能够对数值型控件进行附单位。后来我仔细想了想,按照LabVIEW现在的思维方式,只能够对数值控件附单位,那么在其他运算中就不能够进行单位转换了(例如微积分运算),因此每遇到这种情况后,先要仔细排查一番所给出数值的单位,然后再写出适当的程序,这样岂不是很麻烦?能不能够在其他控件中也加入单位转换功能,这样在今后写程序就不再这样麻烦了! "
1 Comment
usrfrnly
This is a great idea. I think this would be most helpful with charts and graphs.
