Darren
VI Analyzer Test - Limit to Single Line on Strings
Status: New
Any single-line string on a user interface VI should have the "Limit to Single Line" option selected.  Users will expect that pressing 'Enter' on a single-line string will commit the value, and not add multi-line content that they cannot see.
I propose a VI Analyzer Toolkit test that checks for this scenario called "Limit to Single Line on Strings".  The test would return a failure under the following circumstances:
  • It is determined to be a user interface VI.
  • It has a string control set to the minimum possible height for one line of text.
  • That string control does not have the "Limit to Single Line" option selected.
If these conditions are met, the test would return a failure, and recommend the user enable the "Limit to Single Line" option on that string.
3 Comments
Romain.P
Good idea! Is it already available since this time?
Darren
Proven Zealot
This test has not been implemented for the VI Analyzer Toolkit, and from what I can tell, is not provided as a community test either.
Romain.P
