When using waveforms you sometimes find suprising undocumented (or well hidden) features in the attributes.
Some waveform generating (or outputting) vis add additional attributes like NI_xxxxxxx_name->"ABC"
Some waveform accepting vis are able to use defined attributes (the string attribute name will be accepted by writeTDMfile)
I remember graphs showing dedicated plotnames due to waveform attributes.
BUT these features are not documented!
And expanded: each plot property should be accessed by a waveform attribute!
